Hi All,
I started this so I could show what I have done different due to a number of things, The first is the material that I have access to. Have to order every thing and postage can be deadly.
My machines are all metric and conversion differences can add up.
Also my tooling is mostly metric, reamers, cutting bits and drills.
This is where I am up to. I ordered the cast iron for the cylinder at 50mm dia. It turned up and is exactly 50mm with the skin on, done a test cut to clean it up and it came out at 48.5mm, too small, so ordered some at 60mm and am waiting for it to arrive.
The main difference at the moment is the fuel tank, made out of a 1.5" copper "T" fitting and some 1.5" brass welsh plugs. The stand was made out of 5/8" brass bar machined down and I machined the surface that mated with the tank to get a better fit.
Will update over the next couple of days.
Andrew
Andrew
