Brian, I'm glad your found a solution to the piston fit problem. I had a slight binding problem that would go away if I rotated the piston and rod. Since I used all the correct procedures, I couldn't just let it go till I found the source of the problem. It turned out that the die cut threads on the rod were not concentric. I made a new rod to solve the problem.
Those 1/16" end mills will get very easy to use after a little bit of practice. The first few times I used one It was a scary experience. I saw one flexing, and that was enough to teach me to slow down, and easy does it. I have a few 1/32 end mills that I hope I never have to use.
I draw and re-draw parts that I make with no experience, or even a slight clue of basic drafting techniques. Often times I cant understand my own drawings, strange but true. But somehow I manage to interpret the gibberish and get the parts made.
After I saw the drawings you posted with all the machine moves all plotted out and easy to understand, I must say that I'm very impressed. With drawing like that I could really crank out some quick builds!
Edit; I think its worth mentioning that the outer diameter of stock round bar is not "really" round. I believe its "drawn" through sizing dies that are less than perfect and don't need to be. Bar stock needs to be trued up by machining its outer diameter if "round" is required by its application, such as a miniature piston. The outer diameter of precision ground rod is more suited for applications requiring a good fit.
Keep up the good work.
-MB
