Brians Radial Engine
Brian,
WRT the plans for the spokes, I personally would prefer to see dimensions for the holes given as bolt circle radius. I would want to drill them, as well as cut the profile, with the material mounted on my rotab. Given the position on each spoke, a rotation of 72 degrees positions the next.
Just my .02
Metal butcher...
Never look at a build as an entire project. You will only be making one part at any given time. Then you move to another part and so on. Brian already did the heavy lifting by providing you a road map. You only need follow it. Soon you have a whole bunch of parts and you can then begin to think in terms of the whole project as you begin assembly.
Simply concentrate on the part you are making and the overall complexity never becomes much of a factor. You'll quickly overcome that feeling of being overwhelmed by "so many parts". The recent Victorian engine project would have been totally beyond me had I looked at it any other way. Go for it and you'll see what I mean.
Steve
Thanks Brian, I tried that but then I had a bunch of pathced holes that looked funny.
I am working on another now and it looks a lot better (CNC).
Metal Butcher - I agree 100% with Cedge - Any project will have a bunch of parts, you have to finish each one first before you complete. Look at one part at a time.
I have built a few motorcycles from scratch and to look at the finished bike it looks hard to do. One part at a time adds up to an easy build, the hard part is getting everything to fit right and look good.
-B-
Hello Mr. Rupnow. I don't know if this is an active thread, but here goes!
I am a teacher who teaches CNC machining (manual programming, CNC machining and MasterCAM) in a trade school in Montreal, Canada (school name : Cente Anjou, see : www.cspi.qc.ca/centre-anjou/). We have about 15 CNC machines (milling and lathes) and three of our new machines have CNC rotary tables. We also have three CMM machines for accurately inspecting all the parts.
I am looking for a real cool project for my students and I would like to do your radial engine (AKA Brian's Radial Engine). What I really like about your engine is that there are no really small fragile parts and the engine parts would be easy to machine on our CNC machines. I would like to know if you would give me permission to use your radial engine as a project for my students.
If so, I would like to ask you a couple of questions.
CONROD HUB : After studying your drawings for quite a while, I would like to know if I have understood the mechanism properly. If the master Conrod is silver soldered to the Conrod Hub, that means that it never pivots (just thinking to myself !). If I understand correctly, the other Conrods are also fixed and do not pivot because they are fixed with Loctite. Is this correct? If this is correct, the only reason the engine can rotate is because the Cylinders pivot and the Conrod Hub probably rocks slightly back and forth for each revelation of the Crank ? Or is the the Loctite just to lock the small 1/8 inch rod that holds the end of the Conrod pin in place ?
If so . . . . I was thinking of doing a modification. If the above paragraph is correct, could I replace the Conrod Hub with a solid pentagon hub (with no groove) and drill and tap 5-40 at the correct spot on each face. The Conrods could then be simple threaded rods. Or am I missing something ?
When I first looked at the plans I was sure that the other Conrods (other than the master one) had to pivot in the Conrod Hub or they would break.
CYLINDER : I always buy Machinist's Workshop and Home Shop Machinist (that's how I found your engine !). So, after reading your explanation on page 26 of the Jan/Feb issue of Home Shop Machinist, I had a question regarding the path of the airflow in the engine. By the way, I took the liberty of changing the Air Inlet to an NPT pneumatic fitting (so my students can practice tapping NPT). I can follow the airflow path, starting from the side of the Vertical Stand, up into the circular annulus, into the (5 arm) Main Support Frame (via its own circular annulus), up the length of the arm and out the hole on the face of the arm. After that I presume it is the rocking action of the Cylinder that permits the air to enter into the top of the cylinder, pushes the Piston down and when the cycle is finished, the cylinder rocks (pivots) the other way (as the piston rises in the cylinder), letting the air exit by the other hole that goes completely through the arm. Is this correct ?
NOTE : I am using MasterCAMx7 to do all my drawings (production drawings, solids, etc) and to generate the G-codes to machine the parts. If you give me permission to do this project, I will keep you posted on my progress. I am attaching a screen grab of my progress so far.
Other modifications :
I will also be adding a small SHCS, screwed into the back of the flywheel so the student can rotate the engine manually and thus show off the interesting movement of the mechanism.
Wow--You sure reached back a long ways in time to find this thread. You have my blessing to use the plans in any way you want. Its been so long since I built it that I had to get it down off the shelf and have a look. Although the master rod is fixed in relationship to the center hub, all of the other rods do indeed pivot at the central hub. They have to, or it wouldn't work. Forget about a pentagon hub and the threaded con rods. If I mention Loctite in that area, its a small dab of Loctite to hold the pivot pins in place in the central hub, otherwise they would work their way out. You have the airflow mostly right. The annulus is used to feed pressurized air to the cylinder to make the piston go from top dead center to bottom dead center. When the movement of the central hub forces the piston from bottom dead center to top dead center, the cylinder rocks the other way so that any air trapped ahead of the piston can escape.---Brian
Hi, Mr. Rupnow.
Many thanks for giving me your permission to use your engine. Also, thank you for the explanation of how it works, this will help me in doing all the parts and the fixtures. I will keep you updated on how we are getting along making all the parts.
Lorne Wilkins
