Rudys Radial 5
dreeves
I am making 2 more radial 5 engines as gifts for 2 very good friends. I will post pictures as the build goes on. I have started on the cylinders first got some work done but got a lot more to go about 2.5 hours in the 12 cylinders so far. I will post pictures later today. I got to get back to clearing the 16 inches of snow that fell yesterday :)
Got some photos of the work done so far
Clyinders cut to length.
Drilling first hole
Second Hole with larger drill prior to reaming
Reaming .500
Setup to cut the register for the Crankcase. I used two indicators to make cutting 12 cylinders much easier.
12 cylinders ready for more work
More to come
dreeves said:
More to come
Goodie! Goodie!
Guess you got the snow cleared. Me too. Happily the sun came out to work the driveway some.
2 more? Is there a build thread of ones you've done? Or a pic?
More done on the cylinders. I made a manderal to hold the part via the .500 dia hole to turn the outside to .938. I will also use it to turn the fins latter on. Got all 12 done in about 1 hour.
All Done for know
I will Buy .0005 over
I might have felt okay if you'd said 1 in an hour....but 12?
That and shoveling 16" today? You must have cheated. You have a snowblower don't you?
Yes I did cheat with a snow blower.
I got some more done on the cylinders today
First pictires are drilling the 6 exhaust holes
Next switched to another fixture to hold the cylinder
Indicating the Cylinder to center ( I only showed 3 views it was to hard to get the rear shot)
Drilling the cylinder head holes
Next is tapping the 48 holes in the 12 cylinders. Im making 2 extra just incase
Looking good!
Tapping hole and surface grinding are the 2 shop things I least favor.
Building for friends? You are a friend indeed!
Chuck
Got some work done on the Radial 5 build. I got the 12 cylinders tapped thats 48 holes.
Here is the holder I made to hold the cylinder for drilling and tapping the head holes
Here Im setup with a spring center and tap wrench to tap the 48 holes 2-56.
I will be starting on the crankcase soon and will post some pictures of that setup as well.
Well It has started to snow again so got started on the crankcase's for the two engines.
Here are is what I started with.
Cut each side 72 degrees apart in 3 steps of .050 and the last .038 deep.
Next I centered the crankcase on the bore and center drilled all 5 cylinder holes and then drilled the holes to .625 dia. I cheated on the .625 I used a 4 flute endmill to cut it.
All 5 holes to .625
Next Step was to drill and tap the holes for the cylinders thats another 40 holes. I hate to tap. :wall:
All holes drilled and tapped. ;D
Here are the 2 crankcases almost complete got 10 more holes to drill and tap in both.
More to come.
Thanks Dean.
Very nice stuff.
I managed to turn a half-inch length of aluminum yesterday ;D
I can't even manage the energy to build one of these for myself... and you're building 2 for friends. I envy your energy and your sense of philanthropy!
Chuck
PS... your machining skills aren't bad, either! :bow:
dreeves, keep the pics and descriptions coming. I am building my first radial five and a look at your fixtures can sure help.
You must get along pretty good with 2-56 taps. I have tapped 65 holes already on my first engine and I have a lot of parts to go yet.
I look at a photo of your first engine (a beauty) and it give me drive to keep going.
Thanks putputman. I have built one Radial 5 and one Radial 10. I had all the fixtures to build the engine so building 2 at the same time saves time on the setups. Thanks Chuck for the kind words. The two engines are going to one very long time friend and one who has done many good thing most recient for me. They will be suprised they dont know there are being built.
You're making excellent progress on your engines. I have never tried more than one at a time but with all the fixtures I'm sure it knocks the time down significantly.
gbritnell
