HI all i did a bit more today mad up the Base for the cylinder out of sum stuff named tufnol its like machining wood I had bin told to where a face mask (didnot no i was that ugly ) ;D bin told its nasty stuff i ruffly cut out the Base plat to right sum pics
Say now, that's shaping up quite well K', nicely done. I always have admired engines that incorporated a trunk guide like that as opposed to a slipper shoe and rails.
HI all I have dun rather a lot to day made up the two end plates made up the piston made up the back support for the crosshead mad up the gland nut right sum pics
HI I ant dun much lately but i made up the Bering blocks for the crank their still not finished I'm waiting for a order of brass to cum so i can start on the con rod if you all remember my last engine i Had to S/S two bits of brass together for the con rod right sum pics of WATS bin dun
HI all right I got rather a lot dun this week made the con rod made the Little end mounted the engine on to the base plate it looks good then I started work on the fly wheel I was gowning to mack the fly wheel out of one peace of stainless steel but just to show off a bit its gnaw getting made out of brass and stainless steel the outer rim will be stainless steel and the center will be brass I marked out the brass disc see pic by the time i had finished it had more lines on it than a map of the London underground right sum pics ples forgive my speling
