Hello all, I need two cross drilled holes in a 0.5'' diam bar for my current project. I've done a search in this forum and also using google, but can't find an answer, there is plenty about cross drilling but not about drilling into an already centre punched mark.
The first hole has been cross drilled in the correct position, the project partly assembled and the second hole position marked with a centre punch, how do I now locate the centre punch mark at exactly top dead centre so I can cross drill the next hole.
I have the following gear:
Lathe, mill, rotary table, v blocks, edge finder and the usual array of DTI's. I also have a small good quality 3 jaw chuck mounted on a 3M holder, this fits into the 3M centre hole of my rotary table
I have tried lining it up by eye and magnifying glass. With the rotary table and small chuck mounted horizontally on the mill table, I have a short length of 0.25" rod turned to a fine point held in the drill chuck and by finely adjusting the x /y feeds and also turning the rotay table I think I can get it spot on. A trained tool maker or machinist could probably do a very good job this way but I'm only an office worker with no formal training and very little experience and think that there must be a better way than simply by eye.
