I have recently come by a 40mm (1-1/2") diameter carbide insert shell end mill. It takes 6 AXGT inserts and I am running it on an X3 sized mill, but not too successfully. The cutter is held in an ER32 collet. The mill is in tram. One of the problems that is not possible to overcome is the fact that the tip cutting edges are about 3" below the spindle nose so there is probably some flexing going on.
Is the mill sturdy enough to run this type of cutter? If it is, what speed should I be running it at? I am cutting mild steel and iron castings with it.
Up to now I have tried speeds between 1000 - 1600 rpm with 25 thou depth of cut, but get a lot of chatter. Drive motor is 2 hp and I could turn faster if required. I have also tried varying the feed rate, but that doesn't seem to make much difference.
The Emerald Isle
The Emerald Isle
