1. Prop driver can be any aluminium you have
2.You don't really need an external hone. You can bore a suitable hole in a piece of brass or aluminium, slit one sid eso it can be closed up and use that with some lapping powder to refine the finish on the piston. A similar process is done with an internal lap on the cylinder liner and the final operation with a very fine 1000g powder is to lap the piston into the liner. I'll find a link to Ramon's thread which shows it.
http://www.homemodelenginemachinist.com/showthread.php?t=17674&highlight=etas&page=16
3. you can make up a simple template like a washer with a 5/8" central hole and the other 4 around it. slip it over the spigot on th ebottom of the cylinder and spot through the positions. Slip a stub of 5/8" bar into the hole in the crankcase to locate the template and again spot the hole positions.
4. Any aluminium is fine and brass should not cause a problem
