waterloo traction engine .29 scale
I find it is alot to do with what you are using for scrap electrick
Motor cast is what I use never have hard spots any more before that it was a shot in the dark
Shield time is everything with welding. If your stick welding, remember L.A.S.H.T.
L = arc length
A = electrode angle
S = travel speed
H = amperage (heat)
T = technique
If all else is as it's suppose to be (bevel angle, root opening, landing size, material type etc) chances are it will be one or more of those key points.
On all four lol
the saw mill is run by my other engine last year .....but it shows the mill
Enjoy
Thank you for sharing the video. I especially enjoyed the small sawmill powered by an actual Steam Traction Engine. What is the sawmill modeled after; Frick? I built a 1/4 scale American from castings and plans developed by master modeler Dirk Petersen, now deceased. I have enjoyed showing it at many shows here in the Northwest. But I have had the opportunity to power it with a model steam tractor. Maybe someday. Good show.
Not to sure it was built by a man named Harold Lunny many years ago 1972 I think
