Eventually I would like to build some more complex engines, possibly steam but more likely IC and very probably a stirling engine but I'm a bit stumped as to where to start.
It looks like an oscillating engine is probably going to be the best place to start but being new i don't like the idea of just going off plans and having to trust myself to order the correct grades of materials so I'm drawn in by the idea of a kit that has everything in it, including fasteners/springs/whatever else i might need.
So after some searching I've found a couple of options, it seems the littlemachineshop kit would be perfect
http://littlemachineshop.com/products/product_view.php?ProductID=2594&category=386435363
but I'm not gonna pay to have something weighty shipped half way round the world! In the UK i could only find the Stuart oscillator
http://www.stuartmodels.com/inprod_det.cfm/section/casting/mod_id/51
but i don't like the idea of ruining castings? unless they're easy to get replacements should i mess something up?
the other concern is tooling, all the plans I've looked at assume you've done some machining and will know what tools you'll need to do which operation but i am new to machining so don't know what I'll need, in particular I'm thinking specific things like reamers and taps.
To give some background I run a bike shop and as part of that we a starting to build our own frames, so i am competent as a fabricator (cut/file/weld) type stuff. It is the business workshop i will be using which consists of a Harrison L5A lathe (which is used for mitring the bike frame tubes and making spacers/drifts etc), pillar drill belt sander plus hand tools. The lathe has a bit of tooling but what I'm really lacking is milling capability (which will obviously affect engine choice) the lathe has a limited vertical slide that i have played with a bit, but can really only be used on parts up to 100mm square and for very light cuts.
so, after all that (sorry for long post) what would people suggest?
thanks in advance
Matt
thanks in advance
Matt
