I've got a couple projects in mind that need wheels-- bigger than I want to hack out of solid, so I thought I'd play around making a few wheels and try a few things along the way.
The first wheels should to be around 3.5" in diameter. So, off to find something for rims. A little 3" pipe would be nice since that runs 3.5" OD, but I've not got any stashed away... except this rusty old piece of what's probably some sort of historical oil drilling pipe. And it's rusty. Really rusty and pitted. Been outside for many years. But, half the fun of making stuff is finding material inside other material, so we'll see how this goes. Hack off a bit with the bandsaw and throw it in the electrolytic de-ruster.
Overnight in the de-rusting tank and it's still rusted and ugly, but at least most of the loose rust is gone and most of the red rust converted to the softer black sort (if not, there would be clouds of rust-dust from the lathe, as is now it dusts very little) so on to the lathe to see how deep we have to go to get under the rust.
Hey, there is some metal down there.
A few things of note in the pic--
- The lathe ways are completely covered so no loose rust gets anywhere important. Paper is good because you can chuck it when it gets full of chips and it won't get wrapped badly around the chuck if it gets caught. Paper is bad because it can catch fire if you hit it with hot chips. Don't do that.
- I'm using a ratty brazed carbide roughing tool and taking light cuts towards the headstock with slow automatic feed @ 70 RPM. There's too much overhang and not enough grip for much else.
And on to clean out the insides (this bit was a threaded coupler, so I have to take out the threads):
All cleaned up and ready to whack off a couple inch-wide rims
Way more effort than going to the pipeyard for some 3" pipe, but a lot more entertaining finding good material inside some rusty trash.
Next up; hubs and spokes.
