The title says it all. The metal is mild steel. I plan to drill to 4.5mm then get the final size with an endmill, as the finish seems superior this way. I need a good finish because a 3x1mm oring will slide in here (3mm id, on a 3.6mm id groove giving 20% squash or so. I can adjust the groove ID if the hole is slightly oversize, but I'm more concerned about the finish and its abrasive effect on the oring.
Many different ways to do this like using a d bit drill for the final size - seems good on guns, or turning up a piece of aluminium just undersize and using fine valve grinding paste, or wrapping with cloth and metal polish.
Any help or advice much appreciated.
Best Regards
picclock
Best Regards
picclock
