At least that's the plan, but best laid plans . . . Time to see if what I know about Fusion 360 [and the more I learn about it, the less I do know] can actually produce something using stone axes and flint knifes.
Beam try number 2 - note 1 to self - ensure the item fits within a 6 inch circle, really a bummer to stick a 6 & 1/4 inch on a lathe with a 6 inch max [AA109]
Note number 2 - Always ensure Fusion sketches are fully constrained so should a dimension need to be changed [as above] the rest of the model follows suit limiting any further edits as minimal . .
So a shot of what the beam is envisioned as with a couple of in work shots . . .
Now to rig up a face plate to face it to size and bore the center hole for what will be a bearing support - Hey I'm Tickled I got this far . . .
Robert
Robert
