Ford Quadricycle
Additional pictures of the engine mounted and piston assemblies.
We got the cranks, connecting rods, and pistons assembled. Fixed all clearance issues using a Dremel. We had to grind quite a bit off the cranks which were hitting the frame. The connecting rods were hitting the edges of each cylinder also which was fixed. The front spindle axles are almost complete. Now we are trying to make a jig to help bend the U-bolts for the front leaf springs.
Where online can I get the plans for the Ford quadricycle? A hyperlink if you can.
Thank you in advance.
The Quadricycle is still going...I have been so busy I have not had time to work on the project. Currently we are trying to bend up our own U-Bolts. Also, some tooling had to be ordered and we are waiting for that. Progress pics to come.
The SAMI program (http://samiri.org/) helped bend up the 8 U-Bolts we needed for the Quadricycle. We were then finally able to assembly the front suspension. We also finished a few more pieces and are almost done with the exhaust heads. Lots of great progress this quarter with a couple new enthusiastic students.
Outstanding work!
gbritnell
The "driver's accomodation" is looking good Chris.
And the front suspension looks great too. Well done to all you guys.
Won't be long before she starts poppin'...!
Regards, Ross G
radial1951
____________
I just dropped off all 4 rims to get trued at a local bicycle shop and left the seat with a gentleman who specializes in upholstery for classic cars. The speed adjuster parts are almost complete...then we can finish assembling the steering linkages. Things are starting to move quickly this semester!
The seat is out for custom upholstery and the rims are getting balanced at a bike pro shop. Pictures to follow of our completed speed adjuster and front suspension.
