waterloo traction engine .29 scale
Holes for the stays done .....still a long way to go
I designed and built one like that but I didn't like it's design so I scrapped it and built a water-tube for 5HP. Scrapped that one too as it was a prototype. Still have not got round to the third one, need a mill to do some of the cuts for the welds.
Mill does save a lot of grinding
In this case, the mill is a necessity to make regular holes, about 250 holes, which pipe ends fit into and are welded.--the holes are nice fits. My prototype, I cut the holes out with a plasma arc--very sloppy ultimately bad welds, one with a pin hole that I could not get out no matter how I tried. The steam generator, was, however, a success. Reached 100 psi in about 15 min. The next one will be the same design with a few tweeks.
Making some progress......on small clearance issue
Nice work!
How did you make such a detailed pattern for the smokebox door? It looks great!
john
Bit more done tonight ..... wheel's will slow me down ......and should do some yard work lol
Hi i am looking for Full Plans for the Stephenson Rocket, steam engine, very interested in building this engine, scale does not matter ,Willing to pay for them, but must be complete. many thanks
MICHAEL
MICHAEL
You might like to try the National Railway Museum, York as a first port of call.
Email [email protected].
Home page Home | National Railway Museum
The Emerald Isle
If you run it in Minnesota or Iowa or Missouri ( lots of shows and lots of models) you could have a second safety valve for say 150 or so.
