Hi
I have thought for some time that when I drill a hole that needs to be tapped in the mill it would be handy if I could tap the hole while the chuck is still in position. This is what I came up with. This set has been made to suit all the taps in my model engineering thread sizes, additional holders for metric and imperial will be made as I need them. The set consists of a 3" length of 5/8" steel tube with a bore of 7/16". 6 x 4" lengths of 7/16" steel rod. (there are 6 shank sizes in my set of taps).
Each rod is faced in the lathe then centre drilled then drilled to a depth of 5/8" the 6 different shank sizes.
Each rod is then cross drilled and tapped to take a 3mm cap head to lock the tap in place and cross drilled 3/16" to take a 4" length of stainless steel rod.
Thats it. Job done.
At this years Harrogate model engineering exhibition I bought a metal blacking kit so decided this was an ideal candidate. It gives the tool some protection against the dreaded corrosion and makes it look better.
All the parts were degreased with thinners first. The parts are attached to short lengths of wire. Plastic coated is best. That way none of the solution is wasted blacking the wire. The wire is the sort gardeners use for tying plants.
Here are the 4 stages.
First the parts are are immersed in the de0greaser for 10 minutes.
The parts have to washed in clean water in between each stage. It reccomends running water if you have it.
Next is the conditioner for 1 minute, then rinse again.
Then the Blak for 2 minutes, then rinse again.
Finally the oil for 10minutes then leave to air dry.
The finished parts.
To use the tool simply put the tube in the chuck. Select the appropriate tap and holder and insert into the tube. Fit the handle and tap the hole.
About 2 hours in total to make the tool.
The tool in use, before I blacked it.
cheers
rich
Thats it. Job done.
The finished parts.
cheers
rich
