I have recently finished Gerry`s Beam engine and while i was working on the cylinder ports i thought i would start with just one hole instead of the 3 in the plan, as this may help it to run slowly as it should. I made the valve in the conventional way by carefull milling with a tiny end mill and after fitting to the engine you realise how precise you have to be with the dimensions. so i came up with an alternative method which also could be help if you don`t have a mill. The recess has to be 3/16" and the o/d 5/16" so i thought why not just drill it with a endmill cutter on the end of a 5/16" bar in the lathe and then part it off, i had to make a couple of flats on the sides as you may see from the pictures. but it was so much easier to workout. I fitted it to the engine and it runs just as well. Now i see the advantage of having just the 1 port which still lets in plenty of air.
Geoff
Geoff
