- Jul 16, 2007
- 2,987
- 1,056
I'm wrapping up the build on this engine. I just need to fire it up and make some governor and carb adjustments.
The castings for the head and base are aluminum. The flywheels are very nice iron and there is an assortment of bronze castings for the connecting rod, valve rod, timing lever and some other small parts.
This is a little bit different style hit and miss for the fact that the valves are under the head and have a unique construction and assembly. At first it looks a little crude but when finished it fits the overall look of the engine. Another difference is the timing gears are on the inside of the base casting. This allows the governor mechanism to be closer to the outside of the base and brings the flywheel in closer.
The crankshaft is a built up style but differs in the fact that it was designed with counterweights on the cheeks. With as thin as they are I don't think they will add much counterbalance.
This engine was designed with a set of fabricated points on the side of the engine. It makes it nice because no brackets need to be made to use a Hall trigger. A conventional or electronic ignition can be used.
Now for some pictures.
George
George
