I have been offered the following band saw but is it likely to be as useful as it looks. I sometimes get over enthusiastic and buy stuff that is nice but really doesn't get used, hence the request for others opinions. It is rather overkill for a model shop but then I think it will never wear out in my lifetime and is much cheaper than a new small saw from Machine Mart or similar.
Description
Do All Vertical Bandsaw / Band filer
Throat depth 36inch,
Main Table size 30 x 30inch, secondary table 20 x 17inch.
Has blade welder and grinder.
Infinitely variable speeds,
Coolant
3phase 440volts
Ex Toolroom
Price is £250 delivered
Takes blade from 1/16 to 1 inch, 162 long it has been mostly used with 1/2 inch blade as the rubber surface of the bottom wheel is worn on the front half only, not down to bare metal yet but can it be recovered when it does and where (in England)?
I can just fit it in the shop, do have the power to run it and can get bandsaw blades made up at £18 for bi-metalic 14TPI but cannot find a source for band files, any ideas.
Will however have to get rid of an Accuraturn peg board automatic lathe to fit this in, I've never even set that up so it won't be any real loss. Does anyone want it cheap?
Richard.
Description
Coolant
3phase 440volts
Ex Toolroom
Richard.
