HennieL
Hello everyone,
I'm a new member, and after the obligatory first post in the Introduction forum, I might as well start my first real post by introducing myself and my workshop...
I'm 64 years old, and live in South Africa. I'm a soon to be retired civil engineer specializing in road construction, and have been making custom knives as a hobby for many years. I like to work with metal and wood, and just love the outdoors and hunting. Anyway, as I said in the Introduction, I've been participating in the "He-who-dies-with-the-most-tools-Wins" competition for many years now, but still needs a LOT more tools before I can really be competitive
Unfortunately for me, I've had to scale down on the knife making due to bad arthritis in my hands that has now progressed to the stage where I cannot comfortably (or safely...) hold onto the knife blades being ground, prompting me to look at starting with model engine building instead (where the machines can do the clamping, rather than my hands
So, as promised, here's some photos of my current knife-making workshop that will probably be used "as-is" for the model engine making, and then a few of my "half-a-garage" workshop where I mainly play around with all my non-knife-making tools...
First the knife workshop (roughly 3.0m x 3.5m in size):
Some hand tools, storage shelf and cupboards, and a sturdy wooden work bench. The small oven in the corner has been modified to temper the hardened knife blades, and can also accommodate other smallish sized objects. It is also great for rapid curing epoxies. To the right of the oven are two granite blocks and a surface gauge, and my Tormek wet-wheel grinder
To the left of the above photo is my small mill-drill, used mostly for drilling, but also for general light-duty milling, and a 150mm bench vise. Some knife blanks still to be completed are hanging from an over-head shelf
And here's the most important knife making power tool in this shop - my 2m belt and disk sander. In the background of this last photo you can see my supply of knife-making tool- and martensitic stainless steels, that regularly also get used for other purposes where hardened thin plates of steel are required. Also, note the small dustbin that is usually filled with water directly below the grinder, used to keep the steel being processed cool by regular dipping - the spray bottle of water also helps...
And now the "big" workshop - half a double garage, approximately 3.0m x 6.0m in size:
Visible in this photo is my steel workbench, movable bench grinder, pedestal drill, compressor, (woodworking) table saw with router attached to the table extension, a thicknesser hidden on the far right below the bench, and just a small portion of my metal band saw sticking out on the left - oh, and a very hard-working shop vac that's always underfoot.
My lathe, and car in the background that is regularly covered in chips and/or oil splashes
And lastly my TIG welder and toolbox combination, with an old wooden work bench that I made from railway sleepers some 35 years ago visible in the background, and still going strong...
Well, that's about it, apart from two large steel cupboards where I store most of my power tools and "consumables", and a wood-turning lathe that went into hiding because it was dirty...
Having seen my current set-up, I really would appreciate any feedback, advice and constructive criticism regarding it's suitability as a model engine workshop
Hennie
Hennie
