Polish 4 Stroke
Status
Not open for further replies.
Hi-Fi Wind Amplifier...
Santa Claus :rolleyes:
Am I the only one who is asking himself what this monolog with obscure "inventions" do have to do with the threads subject or with model engineering?
Nick
Nick
It's good that you have a brightness that these inventions ...
Well, you can do the models..
So you have to explain what is so innovative about a Venturi jet.
Giovanni Battista Venturi lived from 1746 to 1822. I guess he invented it while he was alive, not 190 years after his death.
Nick
Besides some really funny ideas this thread is very interesting from another point of view. You can't patend inventions that have been already made public. But you can still patend new applications of these inventions (simple example: application of Phytagorean Theorem). Everything posted in this thread is public, no matter how crazy...
Yes
So interesting what you can find in my archives. The oldest Radioamator I found in my ...
Google translated :
"According to information published in one of the writings of English - has been developed by researchers at the concept of electricity generation by passage of ions and electrons with very high speed through a magnetic field
The practical implementation of this method that was based on Plasma gas forcing by the strong magnetic field. Electrical power of 1000 KW can be obtained by passing the said plasma at 3 times the speed of sound, the magnetic field of 1 meter long between the poles of a magnet at a distance from each other by about 15 cm. No, you would need the boilers and steam turbines. Previous experiments have generated so far a small amount of electrical energy. Achieving the full effect expected after several years of further intensive tests conducted"..
A song about Christmas Eve from Santa Claus :
http://www.youtube.com/watch?feature=player_embedded&v=sMCZ4mjnLqs
Andrew
Maybe the exhaust manifold to the F1 wear a magnet and additional energy (electricity) have?
Do not give me those numbers alone ... When linearly decreased as the amount of energy ...
it 5 cm in diameter and 1 meter length of pipe that is 10 times less that is = 100 KW
The flow rate is not 900 m / s just say 200 m / s that is to say 4, 5 fold less = 22KW ...
For each cylinder?
Andrew
Some experience with Palasma. In the film, the plasma is formed, even when the current is flowing in the nano-amperes...
[ame]http://www.youtube.com/watch?v=t7s3cvm6CfY[/ame]
And here is video showing that you can do in addition to current, lovely music, which instead of ordinary hum, will be extracted out muffler...
[ame]http://www.youtube.com/watch?v=ISA4sXOyyQI[/ame]
http://www.youtube.com/watch?NR=1&v=G9bT50QZO1o&feature=endscreen
[ame]http://www.youtube.com/watch?v=xXskcNwXIHA[/ame]
Even serious business, what comes out of mufler treat seriously"
" Designing any exhaust system today is a challenge – especially when it is for an iconic sports car with a famous sound signature. Ricardo’s WAVE software was used by Porsche engineers in the development of the latest 911 model"
Regards Andrew and sends best wishes for New Year.:D
My private hand made plasma for cut 100 A
Cutting Torch :
http://www.google.pl/url?sa=t&rct=j...Og48BQveHBuJYucubF7ng&bvm=bv.1355534169,d.d2k
Another way of getting electricity from hot exhaust pipes. Termionic generator, such as the electron tube. Current density obtained is about 10 watts of 1 cm square area of ​​the outlet pipe
http://fti.neep.wisc.edu/neep602/SPRING00/lecture9.pdf
Of course, the acquisition of the MHD generator, which has electrodes inside..
To assist the electron reactions, a high voltage can be applied, as in TIG welding machines,..
Andrew :p
But nothing to prevent the high temperature of the inner cathode acquired using shale gas, or coal.
if we pipe with a radius of 10 cm heated, it will receive its length 1cm, 600 watts, which is enough for the house to its length of 20 cm or 12 KW .... ....
Extremely small heating stove diameter 20 x 20 cm, and everything we have in the house for electricity, including heating ..
In this case, the inner tube should have fins to really depriving heat of combustion.
Andrew:p
And all it may seem laughable, were it not for the dimensions of the venturi nozzle, which can this piece of brass with a film about the rate gyro, spin up to 10 000 rpm at 40 km / h ...
Andrew :)
Of course, I see that freed the next ideas of something we are very happy. Introduced only basis to be developed. Now I am going to have such a number, which encourages the implementation of this idea. Venturi nozzle is one in the figure is the front surface of 3.14 x 2.1 x 2.1 = 13, 8 cm sqare.
6 pieces battery has 6 x13, 8 = 83.0 sqare cm. that is, it is only the surface 8 x 10 cm ....
A man riding a bicycle is at least a surface of 50 x 50 cm = 2500 sqare cm. Theory can obscure the surface without loss, for which he will be hidden. So such sixpack can theoretically put 2500/83 = 30 pieces ... without magnification face of the rider. So these 180 pieces of brass drums ....
Andrew:)
In general.....this is similar to a Sterling engine....Where heat creates expansion and cold causes compression.
I am very sorry..no heat.. similar too windmill.
If on the brass cylinder with electric gyro cut the steps for air, we get a full hybrid-electric-air drive ...For sure the electric motor would be well-cooled, which contributes to the miniaturization ..
Andrew:)
That's an interesting concept Andrew. My only concern is do the venturi's produce any sound at all. I would imagine that at certain velocities they would 'whistle', it might be good for scaring off dogs though ... lol
Status
