Yes thankyou! I've been looking at those, as I have a supply of aircraft grade alloy, and some brass stock....There are a number of different sites that offer free or low cost plans for steam engines. I know you mentioned vertical but the link below is a relatively simple horizontal that would be a good starter, no castings required, or you could build a wobbler if you wanted something even less complicated. Good luck and I hope you enjoy the experience.
https://www.modelengineeringwebsite.com/simple_steam_engine.html
thoughtIt''s not a typo you need to look at the plans more closely.
As Julius often spec's his main parts from aluminium which is not ideal as a surface for a cylinder there is a bronze liner to be fitted that is 48mm OD and 44mm ID. Part 1-07.02
PM Research makes a nice little beginner kit for 70 bucks, with engines #4 & #5 also available if you want a larger size as you mentioned. I enjoyed the build. You can buy a machined version of each if you wanted reference, the drawings are clear, and there are several youtube videos showing setups.
I've thought about powering an RC steam boat with it. Would make a fun project.
I didn't do the build in this video, but I did build the model. It was good fun!Nice work! Well done!
What operating pressure would this engine require, in terms of steam, and boiler size?This is the only beginner vertical I have plans for.
An old Raymond Yates design.
Not too complex.
This was one of the first engines my dad built.
Its a bit small, but you could put the plans on the copy machine and double them in size.
View attachment 155953View attachment 155954View attachment 155955View attachment 155956
It all depends on what you want to do with the engine. If built reasonably well without tight spots but equally without sloppy fits then with no load most "steam" engines will happily tick over on a couple of psi or 0.1bar.
At the other end of the scale if you want the engine to do real work then you will need a higher pressure as energy in = energy out so may want to use 50psi or 3.5bar.
Size of compressor or boiler will be related to the speed you want to run the engine at, at tick over it will need very little volume. On the other hand if you want it fast to run a dynamo of a racing pond boat than the volume needed to run at 2000rpm will be a lot more.
Two videos of a similar design engine one showing how little is needed, the other at speed but still only a few psi
I would disagree with what PAT says about agreed safe boilers, there are many designs that pass regulations or have been built in accordance with local codes such as the Austrailian code. (AMBSE) and are therefore considered safe. You would do well to get a copy of this code as you are in Australia.
