substandard
- Apr 29, 2009
- 65
- 4
I have been reading the forum for awhile and finally decided to try a build. The EZ engine plans looked about my speed so I thought I would give it a try. I had bought a 10" piece of 1/4" x 2" flat steel stock to use for the base and upright. I wanted to use aluminum but there is no local supply and I didn't want to wait. I cut the flat in half which gave me two 5" pieces, I then milled them to make two nice squared 2" x 4.5" parts. Laid out the various holes and drilled them with no trouble.
Broke out the 4-40 tap and on the 4th hole...SNAP. I had drilled a #43 (.089) hole when it should have been #42 (.093) hole. I couldn't get the tap out of the hole so the upright went to the scrap bin, and I started hunting for some more 1/4" metal to build another upright. The only thing I could find was some 1/4" x 1" aluminum bar, but the upright needed to be 2" tall. So after studying a bit on the plans, I saw that all the holes are in the upper half of the upright. :noidea: So I laid out, drilled and tapped the 1" aluminum and placed it on 1/4" diameter brass rods that are 1" tall. This gives me the clearance for the flywheel and makes the engine a bit more interesting. Here is a picture of the ugly little metal nugget. It is sitting on two 1/4" cutting bits to clear the bottom screw heads. I haven't got arount to counter sinking the heads so the base will sit flush. The camera is old and the images are less than stellar, but neither is the machining so I guess it equals out....
