- Mar 1, 2010
- 865
- 82
Brian
Encouraging to hear you had good results with the Nemet carb. My Bobcat build was my first ever I/C engine so I had no yardstick to measure the results. (yes truly a beginner in my case)
As for the valve problem Interesting? But all good info for the other builders. I had thought the valve spring sitting on the shoulder on the head would act to pull the valve and the valve pull the seat into the head. If its come loose either the valve too tight in the guide or more likely the loctite can't stand the heat? In one of the videos of a Nemet engine the exhaust is glowing red hot. (I can't find it at the moment). Then again maybe the Nemet carb is running lean and another source of overheating?
The thought of melted vitton rings? Isn't overheating Vitton a safety problem?
Pete
Pete
