As you are probably all aware, I have just finished a two month build of my version of Malcolm Stride's engine, the Jaguar, which is essentially half of a Bobcat. My engine ended up with many changes, and got rechristened the Canadian Cub. It is a sweet little engine, with a totally enclosed crank-case and an oil sump and splash lubrication. The only trouble is, the engine runs terribly hot. Malcolm ran his with a propeller, which no doubt kept it cool thru the air movement the propeller created. I am afraid of propellers, because at hi speed they become somewhat invisible, and have a tendency to cut off fingers from old fools who inadvertently stick their fingers in the invisible propellers at speed!!! THUS--I have determined to create a small. belt driven cooling fan to keep the temperature down into a reasonable range on my engine. I haven't seen any posts before on similar subjects, so you may find this of interest.
