My first lathe part.
Discussion in 'A Work In Progress' started by Metal_slicer, Sep 15, 2013.
Help Support HMEM by donating using the link above.
  1. Sep 15, 2013 #1
    Metal_slicer
    Metal_slicer
    Metal_slicer
    Sep 1, 2013
    101
    28
    I have been practicing using my new 7 x 10 lathe from Harbor freight. I am using aluminum round stock to practice cutting. I would like to eventually machine my own 2 cylinder engine design but I need to learn how to use the lathe. Here is a few pictures of an engine valve I did.
  2. Sep 15, 2013 #2
    vederstein
    vederstein
    vederstein
    Must do dumb things....
    Feb 26, 2011
    466
    309
    Looks better than my first cuts.
    Good luck.
    ...ved.
  3. Sep 15, 2013 #3
    bazmak
    bazmak
    bazmak
    BAZMAK
    Dec 12, 2012
    1,997
    1,113
    good for a first try and you only get better
  4. Sep 15, 2013 #4
    stevehuckss396
    stevehuckss396
    stevehuckss396
    Senior Member
    Nov 19, 2008
    3,788
    885
    Keep at it! That's pretty nice for a first piece.
  5. Sep 15, 2013 #5
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    Well-Known Member Project of the Month Winner
    May 23, 2008
    10,368
    3,131
    Nice work!! That's the way we all started--One part at a time.--Brian
  6. Sep 15, 2013 #6
    Sshire
    Sshire
    Sshire
    Jun 30, 2011
    936
    255
    Well done. One of the best things I ever did for my lathe was to get A.W. Warner HSS tooling. Check them out.
    Keep at it. The more chips you make, the better it gets.
  7. Sep 15, 2013 #7
    Philjoe5
    Philjoe5
    Philjoe5
    Jul 12, 2007
    1,727
    317
    That's a good looking valve especially for a first timer! Now just make all the rest of the parts that fit around it and presto...you've got an engine:D
    Phil
  8. Sep 15, 2013 #8
    Metal_slicer
    Metal_slicer
    Metal_slicer
    Sep 1, 2013
    101
    28
    thanks for the kind words guys. I have been making more practice cuts trying to get a better finish and it seems some oil and faster spindle speed for the final cut gives a much smoother finish in addition to fine grit sand paper. In my case I was using fine grit sponges.
  9. Sep 15, 2013 #9
    Tin Falcon
    Tin Falcon
    Tin Falcon
    Jul 9, 2007
    7,212
    760
    There is nothing wrong with learning a few basics in aluminum. If fact when i went through USAF trade school that was all we cut. The curriculum call for one piece in steel but for whatever reason my class never saw the steel.
    IMHO get a set of plans for a simple oscillator engine. start with the base and make one part at a time and make sure each part fits the one before. If yo make a part that is out of spec make it over. But make it out of the material for the engine. Before you know it you will have a running engine. once you have built a couple oscillators then make an IC. like a H Upshure.
    Man can not live by aluinum alone LOL.
    nice start.
  10. Sep 15, 2013 #10
    Brian Rupnow
    Brian Rupnow
    Brian Rupnow
    May 23, 2008
    10,368
    3,131
    Do a search for "Elmers engines" Elmer Verbourg was a brilliant steam engineer who posted many simple steam engine plans which are well suited to "new guys" in the machining business. The engines can be run on steam, but can also be ran on compressed air which is very handy for the home machinist. His plans are "public domain" and are posted free in a number of places on the internet. I strongly suggest building a few of Elmers engines before tackling internal combustion engines.--Brian Rupnow
Share This Page
