Modified Y Axis Locking Handles on HF 45 type Mill
miker
I had been meaning to extend these for some time, then an article in MEW #167
by a Mr Paul Hogarth spurred me on.
The original handles are too close in to the base and are difficult to use.
I turned,drilled and tapped two joining pieces and added a piece of threaded rod
with lock nuts and Locktite.
The extended handles fitted. Much easier to use.
I think a lot of these Mill/Drills are similar.
Rgds
Aha! Done deal! Im on my way out to grab some steel.....
so simple to fix, yet a real pain to work with.... strangely, Ive always lamented how difficult it is to reach these screws yet have never given a moments thought to possible remedies....
Thanks mate!
:bow:
Thanks Michael Thm: - a definite mod for my mill as well ;D
Regards, Arnold
Thanks for the kind words.
One thing I must point out is that I discovered that the lock-nuts don't
really do anything. Before I degreased and Loctited the assemblies I found that
the handle end would just wind out of the lock-nut. ::) My silly. ;D
If I made them again I would make the joining barrels longer and drill/pin them.
The only thing the lock-nuts do is give more surface for the Loctite. Having
said all that, they may work as is for ever.
Neat idea,Mike.One of mine has actually a stripped thread,so this might spur me on to doing something about it.Does your machine also having the "pull and twist" locks for the x-axis locks.Mine broke within weeks of buying the mill drill,and even though the supplier gave me a new pair off a parts machine,they didn't last much longer than the originals.Hence I thought I would make up some screws similar to the ones you modified.
Note to self:get off your fat butt and DO something :big:
