I started on this engine last year,before earthquakes interrupted my hobbies.
Made some progress in the last two weeks,and here are a few pics of various parts:
The cylinder is supposed to be cast iron,but I didn't have any,so I used a piece of unknown steel.The piston is cast iron,and this is my second.A "senior moment" on the handwheel made the 1st one too small.
Con rod and fork.The fork is my second,as the first one had a wobbly thread.
Exhaust muffler and manifold.
Crankshaft parts.The shaft looks bent,but that's just an illusion.It's a piece of 10mm shaft out of an old photocopier.The disc is supposed to be silver soldered on,but I'm worried this will distort the shaft.I'm therefore going to fit the disc with Loctite,and pin it to the shaft.
The uprights in the raw,with bearings.I'm still deciding how to bore the recesses for the bearings,as I don't have a boring head.I might have to drag the face plate out of the cupboard,and give that a workout.I've never used it,so that would be a new experience.
There's a flywheel in there somewhere ;D
Jan's instructions give no circuit for the ignition,so if anyone has built this engine,I would be grateful for a crap-o-cad drawing of it.I'm using a 12mm lawnmower spark plug,as I couldn't find any teflon at the time to make one.
Oddly enough,someone pointed me in the right direction and I now have some.
Now to fill the swarf bucket with the remains from that hunk of steel that will become the flywheel.
More pics in due course.
