Mechanicboy
- Jul 10, 2013
- 957
- 345
Can i use water pipe as cylinder liner?
No, use high tensile steel or cast iron.
You can use old drive shaft as cylinder, it's high tensile steel in drive shaft for front wheel drive car. Piston ring can you create from old brake disc who are made of cast iron. Piston of cast iron to example from old cam shaft (no cam who are impossible to machine or annealing, between cams is soft enough to machine).
Read this book who are good to have in collection.
Here is to download the book https://rclibrary.co.uk/download_title.asp?ID=1996
Seven years ago I was in your shoes - reading HMEM forum
to soak the knowledge of experienced guys . //thank you guys again//
Then I start to built my first 4 stroke single cylinder from
junk material. I have found that is not important for first engine perfectly aligned crank shaft , perfectly machined camshaft and its timing and so on.
Important is GOOOOD COMPRESSION + HEAVY FLYWHEEL.
With good compression will run //for short time of course// even badly built engine and you will be so happy to see running your first engine that you will start to build second much much better engine .
The book from 1942.. Really old book
https://archive.org/stream/in.ernet.dli.2015.205331/2015.205331.Aircraft-Engine#page/n1/mode/2up
son Robert and all this about 'inventing thing' is probably arrant nonsense.
George was illiterate and couldn't read or write and ... claimed the ideas came from the blacksmith at the local colliery. The railway line was old stuff and can be traced back as far as the Roman chariots that plied along the Roman Wall. Four foot eight and a half inches- and there is no measurement that remotely ties in and I've been back as far as measurement of the Megalithic times and based on the movements of the planet Venus!.
