S Speedy Senior Member Joined May 3, 2008 Messages 481 Reaction score 17 Jan 11, 2013 #1 I have a afternoon devoted to my webster build and wondering what drill size I need and tap for a NGK CM-6? are the taps common or is it special? hope someone can answer so I can start cutting
GailInNM Administrator Staff member Administrator Global Moderator Joined Feb 17, 2008 Messages 2,326 Reaction score 440 Jan 11, 2013 #2 The CM-6 thread is 10mm X 1.0 pitch. 9mm drill. Fairly common sso taps are available at many auto supply stores and some hardware stores. Gail in NM
johanvanzanten senior member Joined Aug 30, 2009 Messages 26 Reaction score 9 Jan 11, 2013 #3 Hi Speedy, The NGK CM-6 sparkplugs have M 10 x 1 thread. This is a common tap (in the Netherlands) You have to drill 9 mm. (or 9.153 to be precise ) Is that fast enough? Regards, Johan.
S Speedy Senior Member Joined May 3, 2008 Messages 481 Reaction score 17 Jan 11, 2013 #4 Gail and Johan thank you both shop time here I come.
