help fast. NGK CM-6 thread
Speedy
Senior Member
I have a afternoon devoted to my webster build and wondering what drill size I need and tap for a NGK CM-6?
are the taps common or is it special?
hope someone can answer so I can start cutting :D
The CM-6 thread is 10mm X 1.0 pitch. 9mm drill.
Fairly common sso taps are available at many auto supply stores and some hardware stores.
Gail in NM
Hi Speedy,
The NGK CM-6 sparkplugs have M 10 x 1 thread. This is a common tap (in the Netherlands)
You have to drill 9 mm. (or 9.153 to be precise )
Is that fast enough?
Regards, Johan.
Gail and Johan thank you both :)
shop time here I come.
