Demoiselle boxer twin
josodl1953
Rotterdam, the Netherlands
For a very ( very, very) long time I have been considering the build of a Demoiselle model RC plane. The original was built at the beginning of the 20th century by the Brazilian aircraft pioneer Alberto Santos Dumont. A replica was constructed for the film "Those Magnificent Men In Their Flying Machines. It was powered by a Volkswagen four cylinder boxer engine. The original version seems to be flown both by two and four cylinder opposed twin engines.
Following this , I made a design for a two-cylinder boxer engine . I already have a home-built boxer twin ( see avatar) but the main goal was to make a running engine (which it eventually did , 40 years after the first chips..) but it was't meant to "deliver" . To begin with, I started looking what gears I had laying around because they are ridiculously expensive to buy and difficult to make. I found some gears with a reduction of 1:2 and a center distance of 18 mm . Initial bore and stroke dimensions are 18 mm x 20 mm.
The general idea of the engine looks like this:
Crankshaft will be the build-up-type with toolbit crankpins, silver soldered together. Bearing covers on both sides for crankshaft and camshaft bearings
Here are a few pre-machined parts.
Jos
josodl1953
I made a test rig to check the mesh of the gears . I have two narrow bronze gears an one wide steel gear. The bronze gears will be bolted together on a flange to fit on the camshaft. The steel gear will be keyed to the
crankshaft.
josodl1953
I have been working on crankshaft parts. The crankshaft consists of three main parts, the front part, the intermediate crankweb, the rear part and two crankpins made of 6 mm HSS toolbits. The front an rear crankweb have a clamp bolt for the crankpins. The idea is to assemble the crankshaft with all parts centered with a centering pin. Clamp bolts on the front and rear crankweb are tightened and the crank pins are silver soldered to the intermediate crankweb.
After soldering, everything is taken apart, cleaned , assembled with the conrods , and aligned to minimun runout.
After that, the shafts are machined to final diameters.
So far the theory, practice will show if it all works out.
josodl1953
I continued with fabrication of the actual crank, front rear and intermediate web.
After soldering I found that there was a considerable amount of runout so I did some pre-machining before fitting the conrods.
After cleaning up the crankpins the conrods were fitted.
Before finish machining I taped in the conrods to protect them from swarf.
Jos
josodl1953
I have been working at the crankcase. Machined the holes for the cylinders and a lot of drilling and tapping M 2,5 .
And, at last, the icing on the cake: test fitting of the crankshaft assembly in the crankcase.
It still looks a bit lumpy, but since this build is an ongoing process of fabricating and designing I will remove excess material after the main dimensions are finished.
Jos
josodl1953
First of all I would like to wish all of you a prosperous and healthy 2022. May the chips be with you....
I have prepared the camshaft gears. I made a flanged hub and fitted the two gears with four M2 screws. See sketch and pictures below.
I made keyways in the pinion and crankshaft by drilling a 1,5 mm hole half in the shaft, half in the pinion, see the arrow. I will use a 1,5 mm needle as a key. I did a test assembly with a dummy camshaft to check everything, in particular the gear mesh which was fine.
josodl1953
It's been a while since I've been working on the boxer twin. Last in-between project was the rebuild of a 49 cc Solex moped engine.
So, now on with the Deemoiselle engine.
I started to work on the cylinder heads, pre-machining and drilling pilot holes for the valve cages.
josodl1953
I think is is always handy to make a translucent model of a cylinder head to see where all the holes are going, ant to avoid unwanted interference these holes. Rocker arm support is also fitted.
peterl95124
really like that acrylic head !!!, I always make clear acrylic distributors (on a recommendation from a very wise old machinist) so I can see what I'm adjusting. "may the swarf be with you" :) !
xander janssen
Great idea, will do that for my 2VD5. Not only very helpfull to check the design, but later also as a gimmic to show the internal structure of the engine.
