#3 I'll start today's post by showing the the milling set up used to square up and size the plates and blocks that will become the main structure of my build. I generally use aluminum due to its low cost and ease of machining. I carefully picked 6061 over 2024 for the pieces, to make the drilling and tapping a bit easier. The 2024 that I have is also difficult to file smooth without running into the pinning problem that can cause scratches that are difficult to remove.
#4 Below are all of the structural pieces machined to accurate dimensions, and checked during the milling steps, and afterwards to be sure their square.
#5 The original plan (page 125) show the floor to be the same width as the sub base. However, the general drawing (page 144) shows a 'floor' ledge all the way around. I wanted the floor to have an equal protruding ledge on all three sides, and also the same amount in front of the bearing block. So I drew up my own dimensions for a new 'floor' plan. Below is the drawing with the new dimensions I used, and it also includes the mill table moves should any one care to go this route.
#6 Below is the 'table' being drilled for the six 2-56 screws that mount it to the 'cylinder'. the four corner holes were drilled #32 for 4-40 screws. In the drawings I changed all of the 5-40 to 4-40 screws to simplify the build. I do not have any 5-40 screws, and I could only find flat head 4-40 x 1'' long screws to go up through the base.
I'll get back to the 'table' later on in this post.
#7 I spent a little extra time to draw up the machine moves for drilling the six bolt hole pattern in the 'table'. It helped to eliminate the usual chaos and confusion I go through working off of scattered about papers with math calculations. I followed it and the cylinder bolted on perfectly. So I guess is safe to use the info to save your self some time if your building along, or planing to build one in the future.
#8 This group shot shows the progress made so far.
#9 Below is the 'base' being slotted. The taper (draft) on all the sides of the 'base' and 'sub-base' will come last. I'm milling the 9/16" wide by .250" deep clearance slot for the 'crank'. I centered the spindle at .9687 from the bearing block end and milled it out with several light cuts using a 9/16" end mill.
#10 Milling two steps is the first operation needed to create the profile on the bearing cap.
I set the end mill at .125" down from the top of the 'bearing block, and eye balled the cut up to the scribed line. With one side done, I rotated the piece 180 and with one slow pass duplicated the cut on the other side.
#11 The first step in profiling the larger out board 'bearing' block was to reduce the width of the upper part to .750" by milling off .250" from both sides.
Once I reached the scribed line the hand wheel was zeroed out. The piece was flipped over- and- up against the vise stop to duplicate the cut on the opposite side when the hand wheel reached the zero mark.
#12 The bearing cap profile was done the same way as the smaller 'bearing' cap. Lower the cutter .125" from the top and bring the cutter in-and-up (Y-table movement) to the scribed line, rotate and repeat with out a need to move the cutters position by traversing the X-table movement..
#13 The last bearing cap I profiled, I did the whole thing with a file. Nooo, not this time. I did a little trimming that will reduce the filling time by about seventy five percent.
My fingers are still sore, but my finger prints are slowly coming back! :big:
#14 Skip this picture and go to the one below. I goofed, this one was supposed to be deleted. :
#15 This ones better! I determined the angle part of the bearing' block to be 20 degrees. I attached an angle plate to the fixed jaw of my vise with double sided tape (double stick). To set up the piece I added a 1/4' tool bit under the reduced area. Its important to get this right by shimming with cellophane tape if necessary. After the first side is cut away there isn't much to support the piece for an accurate set up when the piece is flipped over to cut the opposite side.
#16 Here is a picture of how-not-to-do this decorative hole. I know better and should have done this while the 'bearing' block was still a full rectangle. To prevent a collapse of the 'bearing' cap hole I added the 'filing button' to give it support, and luckily it was originally machined up to be a fit tight in the bushing hole. I was lucky that it worked without a problem.
#17 In the picture below I machined out the slots for the connecting rods. After plunging through with a 3/16" center cutting end mill I traversed the table along the X-axis till the end mill reached the scribed line. I zeroed out the hand wheel and traversed in the opposite direction to reach the other end and scribed line, and wrote down the number on the hand wheel. After returning to the center of the slot I raised the quill and flipped over the piece. The second slot was duplicated by using the scribed lines as a guide to reach the previously noted hand wheel positions.
#18 The horizontal lines are the center line of the end mill, and the vertical line figures are for scribing the end of cut lines.
Let me know if you would like any additional details or clarification.
-MB
