Having never built an engine from scratch, I figured I had better start with something EZ. The aluminum for the base hasn't come in yet so I started with the cylinder. I had some 3/4 square in stock. The only issue I had was reaming the bore. I guess I rushed it and scored the cylinder. I had to put it in the 4 jaw chuck on the lathe to clean it up. I ended up with a bore of .507.
That meant I couldn't use the 1/2 brass for the piston, but I had some 3/4 rod I turned down to the right size for the piston.
I also used this opportunity to to use some of the filing tips in the thread Dean started. I liked the finish draw filing gives so I think I will leave it like it is.
Of all the photos I took, this is the only one that came out good so here it is.
Thanks to all the guys that came up with the design for this engine.
