What steel for I/C engine cylinders
Mo deller
The designer of the Vega I am trying to build has specified EN8m but I cant find a supply for the few inches I need.
Just wondering if anything else is suitable. They are one piece and lapped with a cast iron ring in the piston.
It also shows a couple of what he calls heavy metal inserts in the crank web to balance. I cant find a supply for that either.
Any thoughts anyone?
Mo ???
Mo ???
Lead or gold? Can't help with the EN8m
Ahh yes brain went wonky. What I meant to say was High density metal. He says it has a specific gravity of 17 which is more than lead.
Mo
Mo,
For what it's worth tungsten carbide has a specific gravity of 15.8 according to:
http://en.wikipedia.org/wiki/Tungsten_carbide
It may be available in a suitable shape as a boring bar insert or the shank of a broken solid carbide end mill.
Also I have seen the idea raised in one of the model magazines of using exotic materials such as depleted uranium! We don't need a toxic waste site in our own shops!
Sorry about the name mix up, eyes don't always work so good before my coffee.
Hi Mo Deller
IIRC it's a tungsten alloy once sold by GLR ( UK )
This is their site
http://www.modelmakingsupplies.co.uk/
The material does not seem to be there anymore, neither does the site seem to be 'searchable'. ???
You could e-mail them to enquire I suppose. I think they were the characters who did it, but I may be wrong ..
EN8 ? Livesteammodels Normally sell by the metre though, don't know anyone who does 6 "
Bluechip said:
Hi Mo Deller
This is their site
Hello Dave,
Yes it was GLR quoted as supplier and I was dissapointed with what I found on the web. As you say no mention of the material there or anywhere else I have searched. I'll have another look and contact them but I am not confident it'll do any good.
Thanks
Peter.
I had a reference to EN8 steel and near equivalents but can't put my finger on it at the moment.
However, if you have never found Ron Chernich's web site on Model Engineering and Model IC Engine Projects you will find much of interest.
http://www.modelenginenews.org/
On that web site is a FAQ by Roger J Schroeder which contains this bit on materials:
http://www.modelenginenews.org/rsch/build.html#A7
cheers, Graham
EN8 - Med. Carbon Steel
EN8e-Med. Carbon/Manganese Steel
EN8m-Semi-Free cutting steel closely equivalent to a SAE1137 or SAE1140
from HERE.
Kermit
cheers, Graham
Thanks Graham, I have this site in my favourites but hadn't found the section on materials so that was great thanks.
Thanks for the other links and info guys I'll check them out.
Mo :)
Guys,
When we balanced crankshafts in racing engines we use "Mallory Metal". It is denser (heavier?) than steel and is used to help balance by adding weight by tangential drilling the crank web.
There is a company called Goodsons that should have it (at least here in the US)
Hope that helps,
Sean
Seanol said:
Guys,
Hope that helps,
Sean
Thanks, I looked it up and it seems to be a trade name for the group of tungsten alloys that the stuff I need seems to be. I havn't yet found a stockist here in the uk though. I will ring round locally when I get a round tuit but have lost the drive for the moment.
Peter.
