Upshur Twin
crankshafter
Hello all.
Well I have to move the Upshur twin project over here where it belongs ," Work in Progress".
Finished coolingfins for the 2'nd cyl. and and have them shrink-fit on the cyl. And pre-lapped both cylinders ;D just have to finish them with toothpast to get the bores real shiny. Think I will use Viton o-rings on the pistons like I did on my Webster.Have had the Webster running for some hours now, and it is a easy "starter" :big:
Ok here are some pix. from to night's progress.
Lapping.
fitting coolingfins on cyl.
And here both cyl.test fit on the crankcase.
More to come
Regards CS.
Very nice crankshafter, looks like you are coming along very nicely. I need to do a search for your webster build because I have on that is in progress. I put it aside to complete my Siamese twin. Once I am released from my nuerosugeon to get on with my life I will be back in the shop to finish it.
Looking forward to seeing more pics.
CS,
Very nice work :bow:
Tell me how do you keep your hands clean ??? Mine always seem to look like a coal miners who forgot his gloves ::)
Best Regards
Maryak said:
CS,
Best Regards
Bob.
How I keep my hands clean? I clean them now and then :big:
Seriously, I have used and German brand hand cleaner for years(Drumex Special)and I recommend it for all of you shop-rats. ;D
managed to make pistons and cross pins tonight. To morrow I start on the cyl.heads think it will be a real challenge. BTW isn't it the challenges that make life worth living.
Regards CS.
Hi all, need help. ;D
Can any of you tell me where to get spark plugs for my Upshur. There is nothing mentioned in the plans. Cyl.head is threaded 1/4" UNF.
Regards CS
CS,
So you clean em - I knew I was missing something
Thanks for the name of that handclean, I'll try and locate some in Oz.
Best Regards
Bob :)
CS
The set of plans I have for the Upshur Twin do include plans for spark plugs - see page 19 (page 19 of the set I have is dated 5-1-98; although the majority of the drawings are dated 2-10-01).
Garry
Rimfire sparkplugs are popular in the USA.
Three of the distributors are:
http://sparkplugs.morrisonandmarvin.com/
http://www.jerry-howell.com/RF-Plugs.html
http://www.mjnfabrication.com/pages/948295/index.htm
There are more distributors also.
I know that Morrison,first one listed, does or at least did export. Their webpage is nice as it gives all the dimension of the entire line or Rimfire. The 1/4-32 thread plugs come in several different reaches so you have to select the reach needed by examining the plans for the Upshire engine.
I think there may be some European distributors also. If you email Paul Knapp at:
[email protected]
he will help you locate a dealer that can supply them to you.
Gail in NM,USA
Hi all.
Some progress this evening to. Drilled and countersunk cyl.heads, most time spent on making the flat bottom drill. Made it from a piece of drillrod, and a piece of a drill-tang as guidepin. Works great ;D
Like some pic.?? OK here we go.
And finaly a pic. of the Upshure in front of the Webster.
Tomorrow it's time for cutting the coolingfins.allready made a cutter for it ;D
CS,
Great work.
Were the flat bottomed holes a special size ??? or you don't like messing up your standard drills to turn them into flat bottom drills - Just Curious and trying to learn a new twist
Best Regards
Maryak said:
CS,
Great work.
Best Regards
Hi Bob
The flat bottom holes is 5.5 mm. I like making my own flat bottom-drills, its easy.
,take piece of drillrod(if used in alu. I do not bother hardening), turn to outer dia. drill hole for pilot. hack saw a + at the end, some filing and diamond-honing and you have 4 cutting-edges a drop of Loctite on the pilot, put it in the pilot-bore, and if you are in the hurry heat with a Creme Brule-burner to speed up curing the Locktite. If some of you like a pic. I have one tomorrow ;D
PS: Yes I build the Upshur using mm-fasternes in SS, mostly 3mm(.125"), hard to find small inch fasteners here in snowy Norway :big:Ski-season has started,jr.and his buddy is going up in the mountains next weekend for off-pist skiing :eek: wish I could join them ::) have to wait until Christmas. OT? OK :big:
Regards CS
CS,
Thanks for that, now I understand. ;D
I would call such a tool a counter bore as opposed to a flat bottomed drill. ::)
Best Regards
Hi all.
Did some progress on the cyl.heads this weekend ;) Get the heads drilled for the inlet/exh.-ports,the bore for the sparkplug, but I didn't have the 1/4"32 tap but I will have one tomorrow 8) I did the cooling-fins as well, with my shopmade .093" mill-cutter.
Like some pic.? OK here we go.
Time to have some
.gif
CS
CS thats bloody awsome !!!
i especially like your home made "T" cutter
what did you make that from ???
i have just bought 5 from the USA but would love to make my own
well done !!
cheers
jack
well done !!
cheers
jack
I made it out of a pice of drillrod. Turn it to dia. hack saw, angelgrinder, file, and diamond hone :big:. No hardening when used on aluminium.
CS.
Thanks for that CS
i use mine on 4130, 4140 carbon steel generally so i'll stick with the bought ones for now
but i will experiment now i've seen it done, i've become pretty good at hardening drill rod for reamers of all types
cheers and great going!!
jack
jack404 said:
Thanks for that CS
jack
Jack.
Regarding making your own mill-cutters have a look on how Mr. Ishimura do it.
http://homepage3.nifty.com/amigos/t_slot_cutter/t_slot_cutter-e.htm
CS
Hi all.
Did some more on the Upshur to night. Soldered the cylinders to the sideplates.
Assambled cylinders with the crankcase ,mainshaft, rods and pistons. Some small adjustments and voila, it turns freely with no bindigs. ;D Lucky me :big:
I know you like pic. So here we go.
To morrow it's time for drilling the cyl. for the cyl.head bolts and then the valves and guides,
rockerarms.
CS.
