I’m about to jump in with a big step into model steam engines.
the lubrication issue comes up very quickly snd has many opinions.
the engine I’m going to get has sliding piston valves rotating shaft bearings
Initially I’ll be using compressed air for power as I haven’t found a suitable boiler I can’t have a fuel fired boiler in my home so it will have to be electric. This will not be available at first.
Over the years in auto racing never seize was the go to for any sliding things nuts bolts shaft bearings eve emergency sssembly lube otherwise motor oil always worked well especially when sponsor supplied. As I got into air guns silicone oils and greases becam the go to lubes they worked very well on rubber Teflon and sliding things. However silicones are banned anywhere painting is done . No need to worry there no painting in the house. But the steam engine has lots of moving parts. I’ll use lubricated air to start with model cars have a huge variety of silicone oils and greases and they work well . So my thought silicone oil would be great in either lubed air or drip injected as needed.
Now when we get to live steam things might change. I know nothing at this point silicone oils don’t wash off easily I saw a note that mineral oil can lift it then wash with soapy water. But this is exactly opposite of what is needed. So will hot steam require at least more oil or maybe thicker viscosity? The only seals on this engine are Teflon piston rings I think they will work fine but the bearings may need heavier oils. I know there is steam engine oil but I don’t know where to get it locally or even where to order it mobile makes the only one I’ve heard of.
So help me out please this engine won’t be run at very high speeds or have big loads unless I come up with some thing for it to power other than a small gernetator. This is s fun table model not industrial power plant .
Thanks
Byron
Thanks
Byron
