RED DEVIL by Zapjack from belgium (EUR)
ZAPJACK
Nice Côte d'Azur
Hello there,
I found on H-MEN a very beautifull engine called RED DEVIL
We don't have engine like that on old continental Europe
I will share with you the construction of this engine
First steps, is machining of the casting of cylinder
ZAPJACK
Looks like you have a good start on what will be a very nice looking engine. I will be watching as work continues on the Red Devil. :bow:
Cheers :)
Don
The next pictures are the machining of the rod.
After thinking, I decide to build one in steel because the original bronze casting need to much machining
And, final, the result is beautiful
At the smal end, I place a self-lub bronze bushe.
Red Devil. I just read your thread very informative. I bought a casting kit at the gears show in August and have started on the engine. I am interested to know if you have finished the engine and have any more photo's and advice on the build. Thanks Jack
Hello there,
Red Devil is now ready to run. I'm now busy with fitting timing gear, ignition, valves springs, etc...
I've lost a lot of time (I'm not yet retired) because I bough a Schaublin 13 milling machine in place of two little millings (Atlas & LeBreton) and a brand new MYFORD Super 7 th_wav
LeZap
Hi LeZap,
Excellent work on your engine. I don't think I've seen many of these built. It looks like you had to stretch your machining setups to get this accomplished.
gbritnell
LeZap,
That sure turned out beautifully!! Any chace we can see a video of it running once you get everything fine tuned?
Regards,m
Bill
LeZap
I too know the torment of not being retired yet, but you do what you can.
Sure would enjoy a video when you have it running.
What scale is built to? It's hard to judge the size in the picture when things are
finished this well.
Peter
thanks for appreciations. The engine is now ready for tests.
Of course, if it doesn't run I send it to waste with old metals :big:
My biggest trouble is the low tension ignition sytem, I never see something like that !!!
Automatic intake valve is also difficult to find the best fitting
A soon as it run, I will post the video
LeZap
Congratulations! Just wait until she runs! It's an awesome feeling. :bow:
