DickDastardly40
- Oct 23, 2007
- 309
- 0
I am tossing a few ideas about regarding manufacture of a built up type 3 throw crankshaft using a mixture of threaded and silver soldered pieces. I am wondering if I can support the elements of the 3/8" dia journals on a 1/8" rod while assembling. I would then withdraw the rod to prevent having to cut out the crank throws.
Whether this would be easier remains to be seen however, to get a decent set up I will have to drill through the journals (possibly from either end) and ream to size.
A hand reamer is tapered for the first 1/3 of its length and you cannot ream deeper than the cutting teeth due to the shank. Going from either end would leave an unreamed portion in the middle.
I have never used a machine reamer but they look as though the teeth are proud of the shank so would possibly be suitable for deeper work so I could go through in entirety from one direction.
I would appreciate the following advice if anybody knows:
The suitability for what I propose
The speeds at which they should be used
I know they are parallel, is any lead in required?
How much undersize should the job be drilled before use?
Thanks is advance for any replies.
Al
Al
