- Jul 16, 2007
- 3,003
- 1,065
I read Terry Mayhugh's post about making the crankshaft for his 289 v-8 engine. While I think it would be more than strong enough given the testing he performed on it I wanted to present my way of making one piece, multi-cylinder crankshafts.
Over the years I have made many crankshafts for engines ranging from single throw to 2, 3, 4, 6 and 8. I have made them from fabrications to one piece units. Crankshafts are undoubtedly one of the biggest pains in model making.
I thought I had posted a thread on building my flathead V-8 engine but in going back through my postings they ended in 2020. ???
As for metal I use what we have in the States classified as Stressproof steel. 1144 grade. With the dimensions finalized I first start by center drilling the stock on both ends then rough turning the front and rear of the crank leaving the front .020 oversize. The rear is left much larger in diameter so that flats can be milled for indexing the throws and still leave stock for the flywheel flange.
Picture #1 the stock rough turned.
Picture #2 the flats being cut on the flywheel end.
Picture #3 the main journals being cut to width but here again leaving .02 finish stock.
Picture #4 the crank rotated and multiple cuts made to remove the main bearing stock.
