Hi
I am in the process of 'designing' a system with a pressure valve which needs to be opened periodically with lowish force, so direct acting is out of the question. The pressure on the opposite sides of the valve will vary so offsetting it with a spring is not going to do it. I have considered using a very small valve to equalise the pressure before opening the main valve, but the time taken to equalise the pressure will be a problem. A butterfly valve will give very low opening force but tend to be difficult to make and they leak.
I have seen quite complex solutions overcoming this problem with a diaphragm but want to know if there is a simpler approach. Any design ideas or pointers to web resources from you expert engineers most welcome.
Many thanks in advance
Best Regards
picclock
Best Regards
picclock
