Potty Finger Engine
SBWHART
Hi Chaps
This is a slight diversion from my Loco build but I've been wanting to build a finger engine for some time and kept my eys open for ideas that would add a bit of interest to the build. I saw thread on her where the chap added some engine turning to a horizontal engine that looked real nice this set the little grey cells going. :scratch:. Then on one of my scouting trips to the scrappy I spotted these
The scrap man saw scrap I saw flywheels.
First job clean up one of those discs
Then grind up a form tool out of a broken cutter, to use as a flycutter.
Then set my indexer over 5 deg, and mount a chunk of 2 3/4" dia ally in the chuck, that ally is way too long but I didn't want to cut it down and wast material as I'm planning on using it on another job.
This is the set up for flycutting flutes across the face with that formed flycutter. Th angle plate is to support the bar against the push from the cutter.
And this is the result 36 flutes across the face of the bar.
And this is what it will look like as a fly wheel hub.
Have fun
Stew
View attachment Potty Finger Engine Sh1-Model.pdf
View attachment Potty Finger Engine Sht 2-Model.pdf
View attachment Potty Finger Engine Sht 3-Model.pdf
View attachment Potty finger Engine Sht 4-Model.pdf
Thanks Zee
Doing that flutting worked out better then I expecting, it just takes quite a while to go the circle (45 min) I did it in two cuts:- 2mm rougher and a 0.25 finisher.
Got a bit more done this morning.
Part off from the bar stock if you tried parting off this thickness in one go you'd end up in trouble, best way is to do it in steps so you keep the groove twice the width of the tool, then for the last bit just adjust the cut so that your bringing the disc to thickness.
And her's the first disc stuck in the rim with high strength loctite.
Looking good :thumbup:
Have fun
Stew
PS added sht 5 of drawing
View attachment Potty Finger Engine Sht 5-Model.pdf
Yet another example of the value of this website. A practical demonstration of how to do something that I wouldn't have known where to start.
Thanks
Thanks
I'm looking at the setup picture and I still don't know where to start. :big: Of course, I'm still a skeeter winger...
-T
Finished off the disc for the other side, and loctited it in position.
One bit of kit I've found very handy especially for getting things clean for gluing etc is one of those elcheapo ultrasonic cleaners, I use it far more than I thought I would.
And here's both side of the fly wheel, I've got to bore it out for the bearing but I'm still waiting for them to come in from Hong Kong, and drill and tap for the crank pin.
That seems to have worked out great.
Stew
Stew
Stew,
Your flywheels look awesome. I may have to try and steal your idea for my next build. I'll be watching your build closely.
SAM
Stew, for a second there.....I though you where making turbine blades. Nice idea, looks great!
Tony
Sam/Tony thanks for your kind comments
Tony:- I guess it will look like a turbine when its spinning, never thought of that,
Stew
More progress this time on the columb, turned a length of ally down to 15mm diameter than transfered it over to the mill and in the indexer with a 3/16 ball ended slot drill put 12 flutes up it.
Then gripping it lightly in a collet face, drilled and tap both ends M3
Milled a little square base up:- sorry no pics.
Then in the lathe by eye shaped up the roundels drilled 3mm and part off.
And this is what the columb will look like.
I want the engine to look like the Temple of Afinger the Greak Godess of Engines :)
Have fun
Stew
A bit off topic
Good crop of frog spawn this year.
OK Stole a few more shop hours and got stuck into the the columb cap.
First op on the lathe.
Then onto the indexer for milling the flats, and drilling and tapping M3 blind
Then back onto the lathe to part off
A quick clean up and a polish, and this is where it fits
Stew
Coming along very nicely Stew. I hope to see it in the flesh soon.
I don't suppose this one will need any magic dust, it looks magic as it is.
While rooting about today, I found an old sketch I did, for working out the conrod and finger treadle length on an horizontal finger engine. I suppose it could also be used for a vertical one such as yours, using a flat treadle rather than a right angled one.
The dimensions are rather critical for getting a good free running working engine with no mechanical locking up, and I hope you don't mind, but I will pop it in here as this is the only current finger engine build.
Thanks John no problem at all
I remembered you saying the lengths were critical, so I kept the lengths the same as in the NAMES engine I've based it on, so I hope I don,t have any problems, if I do I'll bring it round to the master.
Working in a design office I learnt the hard way the importance of recognising critical features.
Stew
Good going Stew; some very interesting techniques. I filed those for future reference!
John thank you as well; that drawing with the ratios will come in very handy. I have to make some "paper weights" as gifts soon.
Kind regards, Arnold
Nice looking column, Stew. You do nice work, Mister.
Dean
That's beautiful work.
And thanks for the happy news about frog spawn. First sign you know.
Thanks Guys
Zee yep frog spawn is a first sign of spring, saw my first Swallow of the year last week also so I think summer is finally on its way.
Hacked the base out today from some ally jig plate.
Then squared it up and mill around the edge with a 1/4" ball slot drill.
The roller bearing arrived to day from Hong Cong £6.50 for 10 including postage:- don't know how they do it :scratch:
So that I can fit in the crank pin they are only 7mm dia by 2.5 thick I was planning to assy 2 to the shaft but ended up assembling 3
Her's the assembly so far.
IIt runs nice and free, but with a slight wobble I intended to drill the fly wheel for the bearing with the next size down letter drill so that the bearing were a tight fit but when It came to do the job I forgot and ended up sticking a 7mm :bang: drill through it resulting in a slack fit from the bearing so I had to glue them in place, that where the wobble came from I think.
And I'm not quite sure about the proportions of the base I may hack a bit more off it,
Have fun
Stew
SBWHART
Man are you pushing the bling factor up to the Nth degree. I can't wait to see how much more bling you have up your sleeve
Tony
