Plan it, build it
SignalFailure
I want to make an uber-simple double-acting piston-valve engine so I thought I'd draw out some plans for a change before cutting any metal ;D
Can someone who knows about such things please cast an eye over this initial drawing just to see if it looks about right?
I know that the eccentric/strap isn't shown the right size or position at present and that there's bits missing from both elevations (to avoid clutter) but I thought I'd get it checked out before going any further. Ignore the colour too, it's just there to help my slow brain. Oh and please excuse the fact that I probably haven't stuck to any drawing conventions and that the design is rather ugly!
Thanks in advance!
Looks OK to me Paul. At least you have got it down on paper, the furthest I get seems to be a rough, back-of-an-envelope, sketch of the odd part - the overall plan is usually stored in wot passes for my brain.
Cheers Tel, whether or not I'll have the stamina to draw all the parts out properly is another matter altogether ;D
More productive to be cutting metal any'ow!
Paul,
Looks good, the only thing I can't see, (doesn't mean it isn't there), is some form of piston rod guide.
Best Regards
Paul I have some cylinder castings of similar size to your drawing , although they are for a G1 loco they would be an easy start for a stationary engine with the bonus that the ports and passageways are already cast in. If interested PM me.
This is as fitted on loco frames.
a little ingenuity would soon adapt them!
Hi abby are you interested on steam loco?
Paolo
Thanks Bob, I was in two minds about that. For simplicity I'd like to omit it as the maximum extension of the rod is only 14mm. I've seen a couple of similar engines with no cross-head guide so assumed they must work reasonably well. A simple guide (block underneath, 'rails' on top) would be easy to insert I suppose. What do you think?
Abby, thank for the offer mate but I haven't got the gear for machining castings... it's bar stock all the way here ;) !
Paul,
With the small travel/extension of the rod (14mm) the best thing may be to make the stuffing box as long as you can and leave it at that.
Hope this helps ???
Best Regards
Thanks Bob, I think I'll try it without first... it can always be added later if necessary ;D
They're very nice cylinders Abby - 'ow much for a set posted to Oz?
Built most of it so thought I'd post a picture (should probably be in 'work in progress' but thought I'd keep it with this thread). Please excuse the finish and temporary fasteners! Just need to finish the valve rod fork and make the eccentric.
Decided to call this engine 'Pug' as it's small, chunky and pug-ugly!
Once it's done and (hopefully) running I'll post the final plans.
Cheers for the plans, Paul! Downloaded for future use (hopefully!)
Gordon
