my first I.C.: a V10
jimmybondi
Hi,
in Q & A i've published som photos of my actual project
http://www.homemodelenginemachinist.com/index.php?topic=11906.0
but its a project in progress and should localized here :)
the motor (cylinder) block - made of a block of alu 100 x 100 x 200:
roughing:
image.php
(sorry for bad quality of some pictures - i've made them with cellular phone cam)
finished outer shade:
image.php
next i've made the oil pan - i don't have a picture of it standalone atm - but here fixed on the block:
image.php
(down you'll find a picture of inside ...)
now a tricky job:
the hole for the crankshaft - diameter 42mm - length 194mm
done on my minilathe:
image.php
whats next ?
oh yeah - 10 cyl holes:
image.php
inside:
image.php
(at this moment 5 days are passed since starting this engine)
Frank
then i made a few days pause because of christmas and familiy and the holy **** :) ...
the last 3 days of 2010 i spent on several parts which need some more attention:
cyl bushes - made of 9SMn28k - called "Automatenstahl"
it has some lead in its alloy - thats not bad for the piston running area :)
image.php
outer diameter 28mm
inner 24mm
then i pressed them into the block an finished the process on the bore with a "reamer"
image.php
also the heads i've machined last days of last year:
not finished at all - but most chips are gone:
image.php
small group photo:
image.php
take a look into breath ways:)
image.php
and last parts of last year are the pistons - here is one:
image.php
more comes next ...
2011 started with pston rings - made of cast:
image.php
image.php
the piston isn't finished here at all - but see later this month (or year :) )
now a job that is more the more i build cylinders:
cams - on this machine 20 by number :-(
image.php
20 on a rod:
image.php
material: C45 - 1.0503
its able to be hardened up to 60HRC - enough for cams i think
and the crank shaft is finished too:
image.php
here some parts to explain how its build:
image.php
to be continued ...
Frank,
Thats some impressive maching in a short space of time.
When you line bore the hole for the crankshaft how do you adjust the tool to cut the correct diameter?
yours
Peter
returned :)
now follows a terrible job:
the bearinghousings for the cam :-(
48 minimized parts - only to carry a small bearing (bearing type HK 0408)
image.php
that evening i felt every bone in my hands from deburring :-(
but in my head i stay on the next job - a job i'ld like :)
first personalized parts of the engine
crankcases
first a front view at actual build status:
image.php
and that noone should have to ask: it's a V10 DOHC:
image.php
and noone should have to ask who's the builder :) :
image.php
now i've to finish the timelapse collage:
thats the actual status
i think i will ask several thinks about I.C. within the next weeks ...
Frank
Hi Peter,
hard to explain - but give a try :)
(tomorow i can take a photo)
the bore rod (or how its called) has got a flattening near the hole for the cutter.
On this flat area i fixed a plate with a extra fine thread (M4 x 0,25) to pull out the cutter.
the last 5 machining passes i pull out the cutter 0,1mm - to get a acceptable surface and a hole with close tolerance
Frank
Hi Frank,
thanks for the quick reply.
I think I understand your method. Did not realise M4 was made with such a fine pitch. ( I'm still stuck in the past using BSW & BA :) ) Must give very fine tool control.
Peter
yes - or better: no
fine M4 thread: smalest pitch was 0,35 - but who cares what i'm building ? :)
i've made a tap of silversteel to bore a M4x0,25 hole and made a small screw too :)
(my bonelle has a thread M48 x 0,5 for the dust covers - never heard before about such a thread :) )
Frank
Looking great so far, Frank. How long is the bed on your mini lathe?
between centers 450mm
after some modifications are 550mm possible -but:
than i can't make really chips because its very instable
Frank
Jimmy,
Very cool your project !!!
Good job!
Alexandre
Frank,
I've said it before but a repeat is in order - you do beautiful work. :bow:
Best Regards
Frank,
We will have news soon? ;)
Post more news, please... this project is very cool !!!
th_wwp
Best Wishes,
Alexandre
Hi Alexandre,
believe it or not :
there are days where i don't made new parts .-(
today i hardened the cams, made some pre-work for a tube bender
calculated a little bit, arranged some parts like sparks and a carburetor to take dimensions ...
made a piece of CF53 (1.1213) soft to build a tap
ahh - very important:
i made a tool for milling the time wheels !
but while i made them (i made every time 3 tools when i need one !) i thought about another profile (and will use it ...)
here is a lot to do in the peripherie :-(
i will show when there iss a new thing to see.
but from now on there is low output by a lot of work ...
be sure:
it will be continued :)
this week i will finish the tube bender - nothing to show here in this thread ...
also tools for sync belts ... (a lot of work and nothing to see .-( )
and a lot of things that i try to do in a way and learn: this way iss wrong :-(
But: it makes me a little bit proud that you (and others) ask for the progress of this project ...
i love this american forum for its participation (their users !!) - its very cool and smooth and ... (words don't come easy 2 me)
Frank
BTW:
here shows the clock half past 2 in the night - you see:
i can only write in the night - when working on my machines is impossible :)
(please don't take every word seriously that i wrote down here - i like a little bit humor :p )
Frank,
No problem, I understand absolutely !
Since you continue to share your progress for us... ;)
I hope to get a lathe and a mill to start building something soon.
I have some drawings of a V12 for the airplane model (see Mr Weitzel in http://www.wawu.eu).
I also like the work of the Germans... the VTH website (http://www.vth.de) is very cool... I would want to understand better your language... However, the Google Translator helps me a bit... better, helps me a lot!
Best Regards,
Alexandre
Wonderful project. :bow: :bow:
Pictures of the tool making would be good too. ;D
Ron
Frank, this is a fantastic build. Please, post some pictures of your tools - I would like to see the tube bender. Love your built-up crank too. Due you have the book by Schillings?
I love that crank......alot
I'm taking some serious notes here
Hi,
the last days i "learned" to machine a wheel for the timing belt
(20 teeth HDT3m - width 16mm for 2 belt of 6mm width)
image.php
image.php
image.php
and made a flywheel
(a clutch will be added too so far ...)
image.php
Yesterday i parsed a comercial carburetor of a .60 engine and made a downsize and made it a little bit smarter
(maybe i will put 1 of them on my engine)
image.php
you may compare them here:
image.php
the bottle cap of my native beer shows the size of both :)
and after this work (measure,sketch,build) i take it as my personal reward :p
Frank
