Carrying on from previous post...
Thursday was a public holiday here in Namibia as well, so I got some more done
Finished the packing gland and nut - sorry, forgot to take pictures. Not much for a day's work...
I drilled, bored & threaded the cylinder head gland part for M10x1.25 (I chose the metric fine, as it is a finer thread & I happen to have taps and dies for this, as I needed to buy them for making some parts for putting a new engine in my old Toyota Hilux; the Japanese seem to have an affinity to metric fine threads.
I fabricated the nut from a piece of round 3/4" brass, and finished off the hex-head using the dividing head and a threaded arbor I made for machining a new clutch arm pivot for aforementioned Hilux.
Today I made a couple of laps from broomstick to hone the cylinder - one for coarse compound, an an identical one for fine compound. As I don't have a SWBDMO, I rule the kitchen, so I got some aluminum foil to cover the bedways & important parts while lapping. Each lap also has a split sawed in the end, so that I can use a wood screw to turn in to increase lap-size. Turns out, I didn't need that
. After finishing with each lap, I used more kitchen consumables - known as cling-wrap, and after marking the lap with the compound used, wrapped it up, "just in case".
Well, things were going too smoothly... With lapping done on the cylinder I had a "Arnold, you're a Freaking IDIOT" moment. I've been carefully planning on how to do everything, but it seems over-eagerness got the better of me...
I was actually planning to first mill a flat on the cylinder for the steam passage connection, and drill the steam ports _BEFORE_ lapping - this makes sense doesn't it? Well, I didn't do it :-[ - so, I have burrs on the inside of the cylinder after milling the flat and drilling the holes. For now, I used a grinding stone in the Dremel to clear that, but if it is not good, I'll have to redo the cylinder. Ah well, LIFE happens ;D
As I don't have a milling machine yet, all milling operations are confined to the Myford and the vertical slide. My plans were to use a piece of 20x16 brass bar to make the steam passages and valve block, but I could not get any - at least not in my current financial bracket. I was thinking of using a steel solid for this, but, fortunately, before I tried to tackle that, I had an idea :idea:. I have a 200mm long piece of brass tube 100mm OD 60 mm ID my dad left me here when he retired. Can't I coax a bit of 16x20x39mm rectangular brass from that? Well, some measuring, drawing and bandsawing produced it :big:. I first sawed of a 50mm long disc from the original. This I mounted on-end in the bandsaw and sawed of a part as in the one attached picture. The left-over piece can be coaxed into more rectangular/square bits, so not too much of a waste - I don't think I'll need the original size too much, except for making flywheel outer rings like Foozer
As the Myford & vertical slide was set up nice & square for milling the flat on the cylinder, I just fly-cut the hacked piece of brass as well. Tomorrow, I'll carry on with cutting the steam & exhaust passages in the block, as well as the valve cylinder if possible.
Pictures:
1. The coarse wooden lap after use.
2. Coaxing a piece of round brass tube to give up a rectangular section :big:
3. Fly-cutting the above brass to a rectangular block. (I made the fly-cutter as one of my first lathe projects. This year, we had far-above normal rainfall which leaked into puddles in my workshop. A lot of my "things" rusted
- I'll have to spend some quality time de-rusting everything (Marv has a good solution for that
4. Where I was tonight - Cylinder assembly,packing gland finished, and brass block for valve & steam passages part-way. Flat milled on cylinder and ports drilled.
Now, I need to make some grub and pacify Shrek the African Grey parrot who owns me, and is insisting on some cheese, potato and apple ;D
