Humble beginnings
john_k
Good day all,
Been lurking here for a long time while I got together the wherewithall to make something. After a couple of false starts I settled on the River Queen. Now I have been in engineering for !! years (censored to due extreme age) and I'm still trying to figure out how anybody could put this forward as a beginners project ! However, persevered and (having made almost everything twice) would like to post the results of my first effort here for your amusement. Still a bit of finishing off to do: have to attack the connecting rod (too wide and fouling on the bottom of the cylinder), shim the valve and to install the plumbing. I believe the valve has been a bit of an enigma in the past: I will be pleased to share the results my efforts in this respect within the next couple of weeks.
cheers John Kearsley
Good day all,
Good day all,
Your engine looks like a kit I have from the Unimat company. Bought it years ago and started on it last year, then moved ! When I find it again I will use my Unimat to build it, I hope.
Will enjoy keeping in touch to see how you solved problems of which I am sure I will have many as never having donemachine work before. Am an engineer also, older than dirt!
Good day,
The plan I used is the one from the Unimat kit. I have probably done a few things slightly differently, mostly to accommodate available materials. There were certainly a few "challenges" and if I was to do it again there would be quite a few things done differently. All part of the learning curve. Frankly, with the usual 20/20 hindsight the first thing I would do differently would be to start with something a little more straightforward. Good luck with yours,
cheers John K.
