- Aug 25, 2007
- 3,890
- 715
For years I've been infatuated with the idea of cutting helical gears. While I've always found a way to avoid the use of helical gears, they can add a certain elegance to engine valve trains and they have a kind of fascination about them. I wanted to be able to cut and match gears of different angles, mostly for cross shaft applications but have been put off by the seeming complexity of the mathematics involved. However, I think I finally have it figured out and have begun work on an attachment for my 11" logan metal lathe that will let me cut small helical gears of pretty much any angle and up to about 1" in diameter or so.
This is total experimental and may take a number of iterations to get it to work right, and may come to a dead end at some point if I can't figure it out. It will work by using sliding, rotating spindle. The axial movement of the spindle will be controlled by a triangular piece of aluminum sheet, bent around the hub of the indexing collar. As the spindle is turned, a follower will run along the edge of the angular aluminum piece and cause the spindle to advance at a rate determined by the angle. The indexing collar which has 24 holes, will allow me to index the aluminum angle to cut different numbers of teeth in the gear. By the way, the helical gear on the end of the spindle is just for illustration to show where the helical gear blank will be afixed.
Here's some pictures of what I have so far:
Chuck
Chuck
