- Dec 2, 2008
- 971
- 8
Chuck th_wav
Congratulations. That is a helluvan accomplishment. The simple way that you solved what seems to be an impossible problem makes my jaw drop. It is a real gem.
A couple of questions if you don't mind. From the pics, it looks like the tool spindle is directly beneath the lathe spindle, and that a left hand rotation of the knob at the end of the spindle pulls the blank into the cutter path producing a right hand helix. Does the mating gear need a left hand helix? How?
Is rigidity an issue? If you are like me, you are already designing version 2. I hate to offer suggestions to a genius but would it help to shorten up the distance from the tool body to the gear blank, even relocating or eliminating the spring if possible/necessary?
To add a little drag to help control feed rate and to take up wear, would it help to split the tool body and add clamp screws to close it around the spindle?
More congratulations on an amazing job!
Jerry
Jerry
