From the on line metals guide:
6061 Aluminum
6061 Aluminum is, by most any measure, the most commonly used aluminum alloy. It is specified in most any application due to its strength, heat treatability, comparatively easy machining, and weldability. If that were not enough, it is also capable of being anodized, adding a layer of protection for finished parts.
the fatigue resistance of 2024 make it a primary choice when the application is expected to be under stress or strain for prolonged periods. It is commonly used in aerospace applications.
7075 is the other "aircraft grade" aluminum that is carried by OnlineMetals. Its principal alloying ingredients are Zinc and copper, which make it one of the highest-strength aluminum alloys that are available. In fact, its typical strength in the T6 temper is higher than most mild steels.
6063 Aluminum
6063 is often called architectural aluminum for two reasons - first, it has a surface finish that is far smoother than the other commercially available alloys, and second, its strength is significantly less (roughly half the strength of 6061),
