Getting the most from your Dremel
mklotz
LA, CA, USA
The Dremel is a wonderful, versatile tool in the hobbyist's workshop. While it's meant to be a hand-held tool, I often find it far more comfortable to bring the work to the tool rather than vice-versa.
To that end, I built this jig to hold the tool.
The plastic grip that clamps the Dremel was removed from a Dremel router attachment*. Without modification, it was attached to a baseplate - thus it can be returned to the router jig when needed. The baseplate has a 1/2" square aluminum 'backbone' which can be conveniently gripped in the bench vise when the tool is used.
Attached to the end of backbone is a small adjustable table. In addition to sliding along the backbone, it can be adjusted in height and tilted to various angles. The table has a slot milled into it into which various sliding accessories can fit.
This (staged) shot shows how the jig mounts in a vise (small vise used for clarity - my bench vise was too messy for photography) and how the accesory table tilts. Also, one of the sliding accessories is shown positioned on the tilting table.
Here are some of the accessories. Bottom left is a cutoff guide. For cutting small rod, tubing or screws, the workpiece is held against the aluminum fence and the adjustable depth stop with the bit to be cut off projecting to the left. The whole assembly is then slid along the table guide groove into a cutoff disk mounted in the Dremel. Makes very nice neat, well-contolled cuts.
Lower right is a sliding protractor table. The protractor arm is settable to a variety of angles and locks in place with a small brass pin. Angled cutoffs are possible with this although its primary use is, in concert with the table tilting, to produce compound angles on the 1/8" HSS specialty tool bits I grind for making obscure parts.
The jig shown at the top is a sanding table. It attaches to the backbone as shown in the photo below,
and a sanding drum projects up through the hole. When this is used, the backbone is held vertically in the vise and the plate through which the drum projects acts as a small table. By using very small sanding drums, this arrangement can do a lot of the work one might more conventionally use a filing machine to achieve.
Shown in front is a bushing which reduces the diameter of the hole when smaller sanding drums are used. (Too much clearance around the drum can cause tiny parts to go walk-about.)
* Since I built this, Dremel has marketed an accesory that consists of a tool holder that fits into a universal ball joint base (similar to a Panavise base).
It may be easier to adapt this tool holder to the jig described above than use the holder from the router jig that I employed. Incidentally, this new accesory is quite useful in its own right, especially so for freehand activities like deburring.
Marv
The more things you share, the more I look forward to seeing your name pop up on the list of new posts. I suspect a visit to your shop would be a real treat. Keep em coming... I, for one, find your tools, projects and engines of great interest.
Steve
Steve,
Thanks for the kind words. You're welcome to visit my shop, or, as it's known to me, Garaj Mahal, anytime you're in sunny SoCal.
In the meantime you can see a lot of my work at my project page on our club website:
http://www.schsm.com/html/marv_klotz.html
If anything there especially strikes your fancy, email me and I'll produce a writeup for the forum.
mklotz said:
Steve,
...as it's known to me, Garaj Mahal...
Dang! I wish I'd' thought of that one. What a great name!:)
Marv, do you have a pic showing a closeup of the tilting table mount? I'm interested in how it slides up & down & clamps on the backbone.
I don't have a picture to hand but the first photo above shows the inelegant arrangement.
There's a slot in the table support/upright that's somewhat wider than the (1/2" square) backbone. A tapped hole in the bottom end of the upright allows a thumbscrew to lock on the backbone to hold the table in place.
Vertical adjustment of the table is accomplished via various spacers placed in the oversized slot - one of the spacers is visible in the first photo.
OK I see now Marv, thanks.
Man, with all your nifty jigs & home-made tools, you need to get some plaid shirts and do a PBS sries called "The New California Machine Shop" or "This Old Lathe." I'd pay to watch that show!:)
Sounds a plan. After all, we're up to our ears in starlets out here. Maybe I could get some Heather Locklear or Nicole Kidman look-alike to hand me tools while I natter on about their use. I'm sure that my wife would be ok with that, he said uproariously.
I know this is a "vintage" thread, but I got to examine this jig in person today...as you examine it, it starts to dawn on you how useful it is. Think of the difference between a hand-held circular saw, and a table saw...being able to get precision cuts and grinds with a Dremel would be incredibly useful, when you essentially turn it into a "table" machine. I need to build one of these for myself. Would be the perfect tool for cutting screws to appropriate length. Very well thought out piece of kit, and entirely portable.
Bolster, thanks for resurrecting this thread. I had never seen it before, and now that I have, I've copied it to my plans folder.
And of course, thanks to MKlotz for the original ideas!
Gee, I missed this thread too. I suppose a lot of us who have joined since it was posted don't know of it. Very useful, and thanks Marv for another great batch of ideas. Would be worth building if only for cutting screws to length, but I can see a wad of uses for it.
Thm:
Marv's got a ton of these little fixtures and doodads around the palace I've noticed. I'm hoping to finally get the free time I need to make some of these myself before too long.
Hi Marv, Thats a great little gizmo, set up at the right angles and with an endmill in a square holder you could sharpen or at least just tickle the edges up. Save a lot of time and money on building a tool and cutter grinder. Regards Metalmuncher.
Thanks for all the kind words, guys.
I'll just add one further nuance to the mix. If you stick the "backbone" of the jig in an unused toolholder for your QCT, you've got a good way to mount the Dremel on the lathe.
There's nothing sacred about my design. Use your ingenuity to extend it. As royalty payment, report your extensions/improvements of the design in this thread. :)
First time I've seen this thread too, Marv, You really should have sent your pictures to Dremel first. I'm really suprised somebody hasn't stolen this idea and started selling them commercially. Great accessory Marv, As usual.
Pete
Just to let you know Marv, I have ordered the Dremel holder that you used supplied as a spare part, not having the shaper/router table. The part number is 2 615 294 952 and it cost £7.57 including p&p and the dreaded vat.
Although you say this is not your idea, thanks for putting it on the forum.
I also miss this thread and my dremel just sits there with nothing to do what a shame.
So Marv what wold it take from us to talk you into a little write up on this?
;D
?? I thought that's what I did in the first post in this thread.
You did Marv
I was hoping for a few more shots and some words of wisdom on making the angle mechanism. I will blunder through it and ask you for advise if I run into a snag. As always with your fixtures quite functional and useful.
